bobo244
Is it possible to wire a 2 ch amp to a DVC sub with each channel going to a Voice coil. I know if you wire 2 amps up to 1 sub that each amp must be tuned exactly the same or else the sub will be damaged. Since there is one 1 gain\bassboost\etc. know wont each channel be exaclty the same? So if each channel is sent to its own VC will that have any benefits to just bridging the amp?
Each channel would be seeing a 2 ohm load instead of the bridged channel seeing a 4 ohm load. I got my amp from a friend who got it from the swap shop so theres no specs on the amp. I just know its 2ohm stable and its 1200 watts(and since he bought it for 90 bucks new im guessing that its 1200 MAX)
