Coaxial or component in this situation....
  • 2
malibujack
I have an '09 Chevy Malibu with a blown door speaker. Thought I had it figured out what I wanted to replace the door speakers with but now I'm second guessing myself. I had planned on getting an inexpensive pair of coaxials like the Polk DB651
My car has tweeters in the pillars and that got me thinking maybe I need component speakers. Thinking maybe the factory tweeters will cause some distortion or whatever with the coaxials. I have no intention of adding an amp or changing the head unit so I didn't think components were really an option. Any suggestion?
Secondary question. Is there already a crossover point somewhere in my car since it has tweeters? Can you just swap out the tweeters that come with a component set or is wiring the crossovers still needed?
Thanks
you don't need to hassle with components. you want a speaker with very high efficiency (>90dB 1W at 1m) and you should replace both left and right at the same time so they sound the same. you can leave the stock tweeters, they won't interfere with the woofers you choose. you want a lightweight cone. you need to recreate the factory seal to the door panel, which just means you will add weatherstripping foam around the front of the speaker to get it to seal to the door panel (or some F.A.S.T. rings).
the tweeter will likely have a small capacitor mounted on it, acting as a 6dB/oct high pass filter. the woofer will likely be ran full range. you should be concerned with mounting depth. I recommend you inspect the factory speaker mounting first - to determine what depth you can accommodate.
How To: Remove OEM Radio, Door Speakers, Rear Speakers & Tweeters - Chevy Malibu Forum: Chevrolet Malibu Forums
if you add a component set, you will need to re-wire the speakers to the crossover and it becomes much more involved.
if you replace the speakers, you will need a mounting adapter.
Scosche SAGMHR-634 Speaker Mounting Brackets Install 6-1/2" or 6-3/4" speakers in select 2005-up vehicles at Crutchfield.com
it appears that you have to stick with speakers that are 2" deep or less. Polk dB series has make many people happy when replacing factory
Polk Audio db651s 6-1/2" 2-way shallow-mount car speakers at Crutchfield.com
note that you want the shallow versions.
You might get some inspiration from the install that I did... Delta Audio Install
well they list that frequence response so I will try to use it. Also, does it help to have the marine speakers in their towers for such a thing...
800
The gto 6.5's is what i put in a friends ride and they sound good.i am running the 6x9's in my truck and love em.they get loud and handle power.my...
The GTP 609c cost 142 USD as well as the infinity PR6510cs. as per reviews on the net, the 609c is among the best for SQ/quality music.
14
malibujack
malibujack
Kentucky
malibujack
