crappy power acoustik mono block
  • 4
arty
Greece
hey guys
i just bough a kicker 12" l5 sub and a power acoustik bamf200/1d mono block amp
the sub is 600 rms dual 4ohms voice coil
and the amp is 1100 rms at 1ohm load
i just made a custom box for the sub and connected it
total load on the amp with the connection i made was 2ohms(it was supposed to output 900rms)
at first the sub couldn't play very well(couldn't hit hard as it should)
i was very sad about it but this is just the beggining
after about 10 mins of playing
the amp started to smoke and it blown
the ****ed thing played for around 10 mins and then BOOM
do you have any idea why this happened?
i double checked the connections and everything is OK
i bought one when they were first release a couple months back, and it didn't work from day one. sent it back and got my money back. bought a fusion 2001.d, and love it. i have never had any trouble with PA in the past, but it looks like the BAMF's are garbage. RMA it for your money back, and get something else.
I own a Power acustic PS 3000, At first I noticed a smell, like a sulfuric smell when it was warming up, So I took it easy for the next few weeks, then I stop noticing the smell. So I started cranking it up and now it hits hard and clean and LOUD. . I am thinking about getting one more and running dual amps settup to my t5's... Mainly because I dont feel that this particular amp does rated power that I need.
**** I bought a BAMF 2000/1D last month but I haven't powered it up yet. I guess I should check it out before I actually start redoing the install.
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
12
796
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
883
What amplifier(s) are you using? What speakers? Is this your main battery or is it a 2nd battery? If it is a 2nd, how are you wired up? What if...
635
arty
arty
Greece
Lothar34
edweather
    Jun 27, 2024
edweather
    Jun 27, 2024
