Dayton Audio Ultimax and Titanic (MK4), what is the difference in terms of a car sub?
  • 2
D0ZER
5
MN
I am Looking at 10" subs around 500RMS for around $200 and found these two in that range;however, I am having a hard time figuring out what the differences in their specs mean in terms of car audio application. I tried googling it and I found nothing helpful since I am interested in a sealed box for a car and even the descriptions by Dayton leave me confused. And FYI I plan on using 3 of these (1.3 ohm) with with a Rockford T1500-1bdcp and will use a sealed enclosure and can do up to .85 ft^3 of space per sub and mostly listen to electronica.
Dayton Audio UM10-22 10" Ultimax DVC Subwoofer 2 ohm Per Coil
Dayton Audio TS280D-4 10" Titanic Mk 4 Subwoofer 4 Ohm
TS280D-4 10" Titanic Mk 4 Subwoofer 4 Ohm Specification Sheet
UM10-22 10" Ultimax DVC Subwoofer 2 ohm Per Coil Specification Sheet
They look quite similar in specs. Looks to me like about the only difference is that tall surround on the Ultimax.
Looking at reviews at Partsexpress.com people seem to be having some mechanical failures with the triple joint on Ultimax so unless you can verify that Dayton has begun using a different glue you might avoid trouble by going with Titanic.
The 8's have a frequency response of 40hz and up. So I would cross them over at 60hz and up. And crossover my subs at 80hz. That way I would get a...
6
Tuning as low as PE suggests will problematic (long port) unless you go with a passive radiator.
4
Pay attention to the width to height ratio of the port. The further you deviate from a square shape, the less efficient the port becomes and it...
7
Some people make to big of a deal about high voltage rcas. I had a pioneer head unit with smart sync ( 31 band eq, crossovers TA etc ). I replaced...
4
Ive been looking at amarican bass xd 1222 or 1244 ,and sundowns e series, they both seem very good , can't verify sound quality tho but I know...
37
9K
D0ZER
D0ZER
MN
hispls
Dylan27
    Jun 4, 2024
winkychevelle
    Jun 3, 2024
