Design Questions for 10" Fi SSD Neo in 1 Cubic Ft @ 35 Hz Enclosure
  • 2
slow86
CarAudio.com Newbie
Vehicle: 2013 Scion FRS
Location in the vehicle: behind driver seat (resting on folded down rear seat), sub back/port side
Space available (Length x Width x Height): 13.5” x 24” x 15.5” (exterior measurements, 2x front baffle)
Subwoofer make and model, Subwoofer Size, number of Subwoofers: 1x Fi SSD Neo 10” w/ xmax coil and stiff suspension
Type of Port (Kerfed, Slot, Aero, etc.): Slot
What type of music do you like?: Rap (80%), rock (20%)
Is your goal SPL or Everyday Music?: Everyday
Tuning Freq (Hz): 35 hz
Volume: ~1.05ft^3
Questions:
1) Fi told me 25-30in^2 of port area for the enclosure- but I got input that I should be in the 14-16” range. The above measurements are using 24.5in^2 of port. How much port area should I use?
2)
I calculated a port length (Lv) of 45.5” long for the box to have a tuning of 35.5hz- does that seem correct?
3) Any additional input you guys have before I build this thing?
If you're serious about an 18 in the trunk front firing/trunkwalled go ahead. At least you got electrical covered /w/ a 600rms sub I'd wager. If...
16
3K
Not sure if this is reliable but trying to figure it all out on my own at this point. Does this look good?
767
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
533
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
838
slow86
CarAudio.com Newbie
slow86
Denver, CO
THATpurpleKUSH
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
