ObTechAudio
So I just got my SoundQubed (Audioque) 2200.1D and my HDC3 18" Dual 1. I'll be running the amp on a .5 ohm load, which is lower than manufacturer recommendations (1 ohm). So after much research, it appears that running it at .5 ohms is completely fine IF you have upgraded electrical. So, I've upgraded my stock alternator from 80 to 170 amps, XS Power big 3, XS Power D5100R under the hood, and 2 Kinetik HC600s in the trunk. Should that be enough juice to handle the Q1-2200.1 at .5 ohms, which will be around 2,600-2,700 clean rms watts ?
