Do I need a fuse on the power wire from the alt to the battery?
you don't have too in fact it works best without a fuse, but at the same time your giving up safety if the wire comes loose from the alt it will short out and damage your battery as well as possibly start a fire/explode. I like to double stack fuses on that lead if in a crash and shorted it will blow but it will take a sec.
yes fuse it for safety... fuse at your wires max amp rating
yep max rating, if you look what that is on 3' of 0g you will see why i double them up! and if you check across the ohm/resistance load of them doubled you will see a nice difference!
ABSOLUTELY fuse it, and a 300 amp fuse is spot on.. 1/0 gauge wire varies brand to brand, but 300A is right., Some people will disagree, and say fuses aren't necessary, but they are WRONG. ESPECIALLY between your alt. and battery. It WILL NOT have any EFFECT on your systems perfomance.. BUT, IT WILL protect your system. Fuse it or lose it. Hope i helped you bro... Bring on the haters.
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
571
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
404
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
450
trenthonda1
trenthonda1
Florida
mlstrass
HandsomeSteve
    Jun 5, 2024
HandsomeSteve
    Jun 5, 2024
