Do it yourself wire checking
  • 3
travdood
One of the speakers in my 2011 Volkswagen Jetta will sometimes sound like it's blown. It also cuts out completely at times and another speak did the same but only once.
At first I thought the speaker was blown, but 50% of the time it sounds perfectly normal and very clear. I'm guessing a wire is loose.
How can I open up the console of my car to check the wires? Are there any guides that show generically what each wire looks like and how to make sure they are all good and secured?
theres a very good chance that it has a factory amp that is going bad where is the speaker located and is the vehicle premium sound?
The speaker is on the right side underneath or behind the glove compartment. The system is nothing fancy. Just whatever standard speakers that come with 2011 Jettas.
I'll double check my factory warranty, but from what I understand it doesn't cover anything electrical. How much do you think it would cost me to have it looked at and repaired?
Any chance I might be able to fix it myself? I don't have experience with fixing car stereos, but I'm a do-it-yourselfer kind of guy and hold my own pretty well when I have decent guide to go off of.
My 1964 fender vibroverb. It’s a tube amp for guitar. It has broken many times. But it is a serviceable amp. I can fix it.
73
13K
This is what I ordered from Amazon. https://www.amazon.com/gp/product/B07MXMPHKS/?tag=caraudiocom-20...
5
169
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
686
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
926
travdood
travdood
Los Angeles, CA
travdood
Doxquzme
    May 22, 2024
1aespinoza
    May 22, 2024
