Double baffle or good bracing?
Original wis
CarAudio.com Regular
162
71
79938
Just curious. What's the opinion on when a double baffle is need and when is box bracing sufficient?
My buddy has a wood shop so we're building my box together (in exchange for me wiring his car) and I'm double baffling anyway since I have the space. I'm doing 4 CT Sounds Meso 12's in 5.5 cube net.
But I'm curious and I could find a thread when I searched.
I’m not sure what most people do, but I usually double baffle when power gets over 750 watts rms in any combination of subs. Corners always get 45s regardless, even if it’s a 50 watt sub. 45s in corners strengthen the most likely points of failure and aren’t technically bracing. With bracing i do a 13 rule. Any stretch longer than 13 inches gets some type of bracing, depending on power. Sometimes a dowel rod is sufficient or window pane bracing, depending on how much power is being pushed.
IM NO PRO... I built my box using 3/4" plywood and i used bracing around all edges with a dowel rod through the middle to support the behemoths. Im running 2 18" Sundown X V2's with a salt 4. Ive been running this for a couple weeks now and love it. Im running this in an Escalade and just about everything flexes including the box lol. Im waiting on a few items in the mail just to clean up the wiring but will be pulling the subs out and when i do i will be adding a double baffle on top to help support the weight and probably add some more bracing in the middle. I wish i could have used 1" MDF when building or even 1" ply but couldnt find anything in that size within a 50 mile radius.
For around 1k rms I’ll double up 1/2” for a 1” thickness all around. If doing a flush sub look I’ll add another .75” baffle depending on how tall the surround is
I'm taking them off the midrange pods as they aren't needed. I have a set for the tweeters that are much more important but not installed in the...
20
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
AGAIN sonic does the same install stuff for free as well! Get a head unit with 4v preouts and 6 rca preouts as well they will be setup as front...
19
I didn't read the article, but with those GM Bose systems; either fix what needs fixing, or rip out the entire thing and start from scratch with...
I’m at 3 yrs on my Tucson alternator. W the electrical challenges i faced it’s been worked hard. Thankfully those challenges have been overcome...
99
10K
Original wis
Original wis
2RZ-FE
