false floor
  • 3
get some card board boxes or poster board and use them to make a template for the curves of your trunk. Just make little cuts here and there and if you cut to much or something like that then tape a piece back on and try to get it where you want it.
Then trace it on a sheet of wood and cut'er out
ok thanks for the help man
No reason you can't get the sound you want with ported or passive radiator but if you have no ability to tune the mass of the passives you will...
7
If you order directly from taramps in brazil you can get a smart 3k for $259 shipped...
9
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
7
802
BASSINMYSUBS
BASSINMYSUBS
eminence/louisville, ky
BASSINMYSUBS
