Ford Ranger regular cab suggestions. Only door speakers
  • 3
ryan2022
Hi guys,
I'm looking at upgrading my Ranger that I just bought. It's a 2011, with the regular cab and only the two door speakers. It's currently a basic AM/FM radio.
I'm looking at either two 6" two way speakers in the doors and a 10" low profile sub to put behind the seat, or under it. I don't have a ton of money and would like to wire it directly to the deck if possible.
Otherwise, I'd go with the two 6" in the doors, and two 6x9's behind the seats off of the deck. I'm ok with either.
With such a small cab space, would the two fronts and the sub sound ok? I'm not looking for anything ridiculous, just good clarity and a bit of depth for rock, blues and a bit of everything.
I'm a mechanical guy, so any help is really appreciated!
I'm leaning towards tweeters in the pillars and some decent 6" speakers in the doors. I don't need huge base for what I listen to just clarity. I don't think I want to spare the room for boxes under or behind the seats.
I would recommend getting a line output converter. It pulls signal from your stock radio and converts it into a pre-amp output that the sub amp can use. And i think that the stock speakers should be plenty
Are you using your factory radio?
What is your budget?
Useful suggestions requires useful information.
Head unit, suitable amp, quality pair of components and a decent shallow sub...you will get quality sound with quality components, a good install, possibly some sound treatment in the doors and proper tuning.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
828
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
3K
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
7
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
5
174
ryan2022
ryan2022
AB Canada
Kai Winters
