Ground Zero GZPA 1.4000DXII - Any good?
I have been wondering if this mono amp is any good and if someone has any experience with it or heard anything about it?
it is rated 4000w at 1ohm and costs around 1000$ planning to be running it on dual DD 818s or dual Ground Zero GZNW 18SPL.
Link: Ground Zero GZPA 1.4000DXII
Hope anyone knows anything about these, Thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
View attachment 26551850 View attachment 26551851
I have one running two of Ground Zero GZNW 15x's. It has been great I have the subs wired down to .5 ohm and the amp never strains or gets hot. I have good electrical which helps. It is a great amp you will not be disappointed they do more than their rated power and are built well. Their subs are very well made and the output is very impressive while sounding great.
Simply Space... it's a hybrid Maverick, so the battery is under the backseat on the passenger side. In order to utilize both of the 1000+W 5th...
178
In the following order: DOWN4SOUND JFX653S - 6.5 INCH 3 WAY CAR AUDIO SPEAKERS - I did a good listening of these and was pretty impressed. It...
20
4K
nice! yeah i don't know if that would be enough or not for the bigger setups... people here say it's enough for easily 10kw but i'll research...
14
I do not believe a different box will fix this and I generally distrust those """4 way""" coaxials. You could add some pieces of wood or even...
7
Thanks a lot for the diagrams, really helpful! I also found this youtube video showing how to wire to 2 ohms: Also, is this wiring kit suitable...
31
7K
Bazzheadnorway
Norway, Oslo
disturbed471985
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
