Having issues hooking up 4 channel amp to stock headunit
  • 2
jls7884
I have a four channel amplifier and a set of speakers to go with it that I have already wired up using a line out converter but, I am having issues with it working right. For some reason I do not hear some notes in songs. I have tried using a LOC with y cables to split the two rca preouts to four as well as two LOC's. Either way gives the same result. Any speculation as to what my issue might be would be much appreciated.
Thanks, Jacob
Amp is set to 4 channel mode, speakers wired to each channel, and rca preouts connected to each channel. Does it matter which speaker goes to which channel as well as each rca preout? also I have noticed that if I set the fader towards the front I start to lose signal and eventually lose all signal. Same with the balance if going right. Other directions change nothing for both.
Update I have been playing with the silver flutes and just can not get what I want out of them. I spoke to stereo integrity today and ordered a...
9
https://www.caraudio.com/threads/all-bnib-focal-fdp-4-600-ds18-exl-p2500-1-sundown-audio-sfb-1000-4d-350x4-4ohms.614462/ :)
18
Seems kind of stupid to prevent helping others with advice on equipment from Amazon, doubt that Amazon is preventing this either. Pain in the arse!
14
937
I would Double check the LC2I settings also and make sure all wiring is secure and not loose as well.
I'm not a big fan of Brand X personally. My car idles at 500rpm and my Autotech didn't turn on until 650. I sent it back and he redid it to turn...
4
872
jls7884
jls7884
Sandy, UT
jls7884
Doxquzme
    May 22, 2024
1aespinoza
    May 22, 2024
