Help with box design for 1 12" Sundown X
  • 1
What is the best box size and tuning for this subwoofer to get the most out of it including square port area, port diameter and other important things needed to build a sub specific enclosure? I am going to run it on a Soundqubed 1200d amp so it will be seeing 1200rms at 1 ohm..any input would be appreciated. Thank you
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
841
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
4K
In the meantime you could stuff that port hole with a blanket or some pillows and it would probably sound better, if you want to listen to some...
12
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
okiestylin
Houston, TX
okiestylin
