Help with street a set-up
orangelss
Sedalia
Finally going to try running db drag this year. Looking for help building a street a CRX. Pr 10s, 2-amps, 3 batts is the plan. What subs and amps does everyone recomend? If I understand the konaki hybrids I have are not legal subs //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif. I have a set of APXX motors may talk to atomic about reconing them. Post what works or what you recomend. Box help too.
Ok, well, in street a, i beleive you can only run one amp. Also, you can only run one 650sq in batt.
Two solid 10's (DD 9510's, HD3's, american bass HD's, etc.)
One nice amp (dd Z1, american bass 500.1/700.1/1000.1, stetsom 7kw)
One nice battery (stinger/odyssey 1700, northstar G2700)
One (or two) boxes, subs forward, ports back.
/thread.
Ok so 1 batt 1 amp. Box can not extend past the window line. How far forward can the box go. Also If I'm reading right I can not sub-floor the car?
yes you can run an aftermarket alt.
only one batt no larger than 650CI up front... thats its with the batt.
Tommy K pretty much provided the neccessary info you need.
Can I move the battery from the front to the rear of the car? I also have a or of WMDv.2s 10s. They have custom recones. Can get the pap recones and put them back in. Anybody have luck with them? Does Atomic still recone APXX motors with 4" coils. Yes the motors are for 4"coils.
No, the battery has to be up front.
I wouldn't bother with WMD's. Get something worth using.
Don't bother with 4" coils in street a. You won't have enough power to get their full potential out of them.
Question I have is Have you bought anything yet? Amp;? If not.. What vehicle and what is your budget for subs and amplifier,wiring kit and...
5
143
Just remembered, I have that same coaxial/comp set, BNIB, $245 shipped if you are interested. I have the matching coaxials, took these of the...
12
431
I had this same amp installed about 9 months ago with no issues whatsoever which make all this odd
10
574
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
857
orangelss
orangelss
Sedalia
orangelss
Hobib Ali
    Jun 24, 2024
1aespinoza
    Jun 23, 2024
