How big a box do i need and does it fit?
Hey i wanna find out how big a box do i need for this sub to hit nice? The sub is the 15 inch one.https://ssl.perfora.net/www.ficaraudio.com/sess/utn154f445d1886245/shopdata/0050_Speakers/0010_BTL/0060_N2/product_overview.shopscript
Also the trunk i want to put it in is 7.7 cubic feet. Its a 2000 mustang convertible if that helps any. i wanna know if the box would fit in the trunk.
the biggest box you can fit is the biggest box you can fit through the opening of your trunk. ( mustang trunk openings normally aren't very big. ) make a shell of a box that u think is the biggest u can fit out of cheep plywood. and then go from there
Hmmm good idea I'll try it on my next day off. Any idea what size box i need for the speaker though?
So if i get a box that's l=20 W=18 H=18 and 1/2 inch thick mdf i should be around 3 cubes? (not counting the port) highly doubt that would fit though. I think the 15 might actually be an impossible fit -_-
(Area in trunk for mounting a subwoofer box: Height = 7" towards front, 12" at rear, Width (front to rear) = 26" maximum, Length (side to side) = 34" maximum between wheel wells (trunk opening is only 28")
That's what i was able to find for trunk space. The box's top width would have to be 28" and the height 7" (or have some weird type of box that is 12" and then slants down to 7") and a max 26" depth.
Unless I'm wrong boxes cant have sharp corners right?
The idea i might use is basically 2 boxes one 12" in height and the length would be up until the trunk height lowers to 7"inch and there a 2nd box would be attached to the first into the box. The inside of the box would be like the inside of the staircase. (best i could explain without graphpaper and a scanner)
Yea I don't think I'll be throwing anything like that too it lmao. I think I'll be happy either way I decide to go but I'm just excited thinking...
8
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
3K
edudes13
edudes13
Hazleton, P.A
mklett33
