Image Dynamics SPL 15" Subwoofer RARE only 6 made same as Atomic APXX
  • 1
johnjv29
I am selling my Image Dynamics SPL 15 that is in great shape and sounds excellent!This sub is extremely rare and there is only 6 of them ever made.These were made by Image Dynamics,not just a recone on a motor.This has the same specs as the Atomic APXX but I was told this is actually bigger.I have two of the APX 15's and is bigger than those.There is only one terminal but is a quad voice coil,the coils are wired internally .This sub is a BEAST and with the right box and power will pull some great numbers!The specs are the same as the Atomic APXX,I bought it but really didnt need it.I figured it would make someone a great competition sub or great daily listening.The sub is in great condition and has a some spots on the back of the motor and is only cosmetic the rest of the sub is perfect!This sub will kill your W7's,9500's and most of the competition out there!
I may accept trades,I am mostly looking for amps,large blown amps,wire,HO alternator.
Here are the specs:
* Super eXTREME SPL competition woofer
* high sensitivity, extreme efficient motor to ensure high SPL possible
* Rigid Die cast aluminum basket
* Organic long fiber non-pressed cone body for accurate tight bass
* Highly damped Kevlar and carbon fiber reinforced cone body
* triple layers foam surround increase the power capacity of woofer
* Extended neck joints on cone, coil and spider strengthen the integrity of moving structure for high power capacity
* Compressed mounting ring gasket
* vented coil for extra heat dissipation
* 3 inch high temp aluminum voice coil
* extended, machined cut one piece back plate
* Powerful double stacked high energy magnet
* over 2-1/2 inch long excursion motor structure
* reinforced resin impregnated polycotton spider extend the life span of the speaker from material fatigue and collapse.
* integrated heavy duty lead wire on spider prevent short circuit and melt down
* dome shape dust cap design
* low carbon front and back plate
* Vented magnetic gap technology
* Laser etched, machined and chromed back plate
Make me any reasonable offer,I need the cash for wiring and a new alternator.
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Absolutely. I have an IDMAX 12 in a 1.65 cubic sealed box on 900 watts and it sounds great. You won’t be disappointed. Pull the trigger.
23
3K
I could swear Ive seen those years ago. I wouldnt waste money on it
112
9K
I may get a pair of his 6" woofers for the back. It's an extended cab pickup so the enclosure won't be as bad as a door with holes in it. Highs...
13
johnjv29
johnjv29
kentwood mi
johnjv29
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
