Alright, everybody check this out. I removed the cap, wired the amp direct. Prior to hooking the power/ground to the amp, I put a meter on them. 13volts with car off, 14.7 with car running. Shut everything down, hooked up the amp, started the car, turned on the radio, AND...... Nothing! 4 volts at the amp! What the f***? Still 14.7 at the dist block. Fuse is good on the amp and the inline. What now? Bad remote wire? Does that have the same effect? I am utterly confused!
