JL Sub + Kicker amp.. Good?
  • 3
Atreyix
Hey all, new to the form, and somewhat new too car audio.
I'm looking to put in a sub in my car, I was looking around and I found a JL Sub/Enclosure combo, And I also found a Amp. Links are below. Would this be a good combo?
AMP: Right here
Subwoofer: RIGHT HERE
I already have a wiring kit installed.
OTHERWISE: I was thinking on getting THESE MTX subs, But would only be able to get a THIS Boss amp.
My budget is about $200, and I'm just looking too add some bass.
no...
dont use prefab junk box.
if you looking for cheap but good, look at the soundqbed subs. there very good.
also look at there amps.
no boss amps.
but for only 200 total, your not going to find good for that cheap.
HDS212
http://www.sonicelectronix.com/item_38335_Precision-Power-PPI-P1000.1.html
and some wood to make a box.
its over your $200 but this will get you good.
or look on here for a used amp.
if you get that sub, look for a mono 700/800 rms amp at 1 ohm.
as for the sub if you want to run at 1 ohm you need the d2 sub.
If I may.
OP your selection isn't terrible and you won't find much else for just 200 bucks. I say go ahead and get your feet wet on a bit of mainstream equipment with a prefab box. If you get the itch and really get into this hobby there will be much to learn but for now, to add some low end to your existing setup the Kicker and JL isn't a bad choice. I do agree though that I'd lean toward this over a cheap JL if you've got any budget flexibility at all.
HDS200
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
3K
  • Locked
Clearing out storage. $75 + shipping. Located in Carlsbad, CA. Pick up OK. Shipping weight is probably around 13 pounds. Slightly to deep to...
Kicker q class 12” sub is in excellent condition i got this sub with the intention too build and i dint have the time im asking 250 i am open too...
Not sure on your level of knowledge here. You can wire your sub up 2 different ways, resulting in 2 different resistance (ohm) values. Your amp...
31
4K
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
139
Atreyix
Atreyix
Wisconsin
germanyt
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
