JVC KDSH99, Rockford RFX-9300, or Alpine CDA-7876
  • Thread starter <Collock>
  • Start date
  • Replies 1
  • Views 3K
  • 1
<Collock>
Guest
Ok hears the deal I dont know a lot about Head units so I dont complete know what the best unit is. These three units are all within 20 dollars of each other. JVC and Rockford play MP3 Alpine does not. A lot of people have said JVC is good, this month Mobile Entertainment did a review on 9400 which is the same as the 9300 except it is set up for video. They said it was a good MP3 player and had like preamps tested about 3.1 volts if i rember correctly and amp wattage tested in the mid twentys. Alpine CDA-7876 which is almost the same as a review on the CDA 7875 said" preamps measured 2.3 volts @ 1% THD+N, with the sub outputs faring a bit better at 4.6 volts at the same distortion level. Source impedance at 1 kHz measured about 340 ohms on all preamp outs. With 27 watts x 4 on tap at 1% THD+N" on the internal amps.(http://www.carsound.com/reviews/hd_units/cda-7875.html)
My main question is Alpine is better than the JVC and Rockford in quality of sound? Also what would you buy if MP3 did not matter? I believe the Alpine has a lot more options, but not the eastiest user interface. Opions?
collock- check out alpine web site at
alpine1.com check out there 7878 cd/mp3
player. but if cost is a concern then the
rockfordfosgate 9300 would make a better choice
then the jvc.
Google do it translate what ever i do
4
408
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
Usually when you shop for a replacement harness for your model, you will find the pictures may show you in what pins your wires go to.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
Guest
billetz23
