JVC unit keeps resetting when ignition is off
  • 2
r16ynn
Hello,
My JVC KD-R731BT keeps resetting the options I have set (colour, brightness, demo mode, ect) apart from the radio stations when I turn my ignition off. I installed the iso connecter that came with the unit to my car, as stated in the manual. It works fine apart from that. Any help is appreciated. Thanks
One of the power wires (yellow I think) needs to be connected to a constant 12V source otherwise the HU will lose it's memory when you shut off ignition.
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
Ok thanks I removed the wires from the back of the unit
4
Google do it translate what ever i do
4
351
Hi, if no one here is able to help you figure it out, try over at diyaudio in the car audio section, it is a more technical forum. This is one of...
r16ynn
r16ynn
England
r16ynn
winkychevelle
    Jun 3, 2024
