Making a box for coaxial speakers and cant find any reccomendations from anywhere.
  • 2
nezz
CarAudio.com Newbie
Vehicle : bmw e30
Location in the vehicle: rear deck
Space available (Length x Width x Height): 60cm x 25cm x 10cm
Subwoofer make and model: Massive audio lx46
Subwoofer Size: 4x6
Number of Subwoofers: 2
Type of Port (Kerfed, Slot, Aero, etc.): ?
What type of music do you like?: Techno, rap, pop
Is your goal SPL or Everyday Music?: everyday music
Tuning Freq (Hz):?
Volume :?
Questions: Im not sure if im in the right place since its about subwoofers but il try my luck.
The reason why i want to build a box for them and not mount them in the rear deck is because i get to remove my old speakers and get some preassure into the cabin from the sub.
Hey there, your available space for a box is 0.52cu ft so its pretty small. I supposed given your speaker size of 4 x 6 inches, you could make a box , put a divider in between and make it a sealed enclosure. You may achieve an added thump in the mid-range / mid-bass region but nothing below those frequencies, I am afraid. Its not a subwoofer system that tiny as the enclosure would not allow it to generate bass regions, but if that's what you are chasing, then it should be ok. Also use a little amp with built in cross overs and you may need to tweak it to blend in to your front stage speakers.
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
894
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
Looks like half a dozen other makes/models on the market, rebranded . The shallow mounts look like they’re made by Pioneer but what the hay, one...
8
I think it worked .just odd bc it's brand new but I appreciate it man. haven't had any problems yet
4
Is that speaker in the existing rear deck? Are you running a sub in the trunk?Do you have that speaker on an amplifier?Are you using a stock HU...
5
nezz
CarAudio.com Newbie
nezz
Finland
DRBOOM
Doxquzme
    May 22, 2024
1aespinoza
    May 22, 2024
