More specific amp mounting locations
Mount on box?
  • Mount on box
    Votes: 2 66.7%
  • Never mount on box
    Votes: 1 33.3%
  • Total voters
  • 3
pilotdog68
12
Omaha
Usually in the threads i read about amp locations, people just say "in the trunk" or "under the front seat". After looking around my car, there is no room under the front seat, and, other than the plastic floor, there are no flat surfaces in my trunk big enough for my amp. just for kicks i tried putting the amp on the subbox. it fit so perfectly on the box and in the trunk that now im considering putting it there permanently.
two questions:
really how bad will the vibration/flex from a sealed 300w 10" be on the amp?
if its really bad, what are some more specific suggestions for mounting the amp elsewhere?
thanks
You will be just fine mounting it directly to the box! LOL
I have had 4kw+ rms ported with amps mounted to the box. If you are really that worried about it, I did use some rubber isolation mounts before... just for shits and giggles, I had a bunch of them laying around because I use them for mounting ignition boxes in cars...
I used these and just got longer bolts to go through the 1.5" thick wood... MSD Ignition 8822 - MSD Vibration Mounts - Overview - SummitRacing.com
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Ill check it out. I was actually on the site last week. Thanks!
536
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
712
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
846
pilotdog68
pilotdog68
Omaha
pilotdog68
