Music Pauses When Reversing
kennyboi
CarAudio.com Newbie
Hi I was wondering if someone can help me with this issue?
I have a Jensen CAR687 aftermarket radio that I got installed at Best Buy. I’ve noticed that whenever I shift into reverse, my music pauses and to be honest, it’s kinda annoying. I’ve looked all over the settings to see if there’s a way to fix it but I haven’t found a single thing. Does anybody know if there’s a fix? Thanks
Does the rear camera have a microphone? If yes, then I assume that is the reason for pausing. Check on settings to see if you can defeat the mic. If no, try disconnecting from behind the radio. If that does not work, try connecting backup camera to the front camera input. No idea if front input is automatic, so you may have to manually set it everytime you reverse.
How does that make backing up any safer??
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
Or maybe this is righter 🤔🤣
5
927
1997. Wow. They make it to last. vs. American car? Toyota runs pretty efficient. No complaints.
10
Do you have a CD player connected to your Head unit? If so, does it add more voltage drop or use more power that's noticeable? No overheating...
What's songs do they play in Costa Rica? Some songs I just like. Even if it's Hard Rock. Like Axl Rose, Guns and Roses. They came to Hawai'i...
40
5K
kennyboi
CarAudio.com Newbie
kennyboi
New York
Doxquzme
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
