Need $100 comps.
What model of NVX series V?
VSP65KIT
We pulled a set of Polk MM crossovers out of a door the other day. They where in a bag that was filled with water that looks like it was there for at least a year. Still worked
Awesome build quality!
Wow! No Kidden??
I hope not. That's awesome if it's true.
There is a build log going on of a Charger/Ramrod that has some experience with the NVX speakers that can give you his experience of using them to get some feedback on how they sound/perform
I'll be sure to check it out!
I'll add these on!
Little more than $100 but not sure any of the suggestions can beat these. http://www.caraudio.com/forums/speaker-classifieds/616410-clif-designs-cd-60-4-separates.html Yeah they are mine but incredible speakers for the price
I might PM you in a week or two if they aren't sold.
No joke. I should have took a pic. Water was straight brown
Nasty bruh.
so your labor is worth nothing? I wouldnt work for 36 hours for $1550.
that said, I did help. im trying to help you save money by not buying GARBAGE
It wasn't continuous. And it was doing something I love, working on cars. I know the Alpines aren't garbage, my cousin has the coaxes in his truck. I like how the tweeter sounds on it.
you dont have time to so your own install.. bit you can mess with other peoples stuff? odd
Shots fired! Bang bang!
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
136
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
191
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
143
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
500
Brian21699
Brian21699
Vancleave, MS
Brian21699
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
