Need Advice On Setup In Silverado Extended Cab
  • 1
RodKnockJunk
CarAudio.com Newbie
5
USA
I have a 05 1500 extended cab. Wanting to setup a good system for less than 1k.
I need help choosing an amplifier (would prefer to have 1 amp) to power both front doors and subs and what wiring kit to use and anything else I might need that I cant think of...
I would like to have either 2 10s or 2 12s in a sealed box under the back seat. I plan to use all Sundown Audio equipment. I am planning to delete the rear door 4x6s since there will be 2 subs and front door 6.5s up front. My headunit also only has 1 Red/White hookup on the back. (I like this headunit so I want to keep it).
The speakers I would like to use are:
- SA-65CX (front speakers) https://sundownaudio.com/index.php/products/speakers/item/sa-65cx-co-axial-speakers
- EV3 Series 10”/12” (subs) https://sundownaudio.com/index.php/products/subwoofers-2/item/ev3-series
The box i would like to use:
- https://www.soundoffaudio.com/dual-sub-box-1999-2006-2007-classic-silverado-extended-cab/
I also would like to know if the 6.5” speakers will fit in the front doors depth wise and in the factory holes with no cutting? (Ive heard some 6.5s are oversized).
Thanks for the help.
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
582
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
676
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
3K
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
5
931
RodKnockJunk
CarAudio.com Newbie
RodKnockJunk
USA
RodKnockJunk
