Need amp for dual Alpine Type r 12's Please help
Are you running your subs @1ohm? I ran my Type Rs when I had them off a Hifonics Brutus 1200w, and I'm running my LIs off it now. It's a pretty decent little amp, and it fits in your price range.
He cannot run them at 1 ohm - he can run 2 or 8 ohms
That is why I recommended that MB Quart as it has pretty good output at 2 ohms.
[quote=>>SQL
2 of them? Why not? I ran mine at 1ohm....
2 d4s wire down to 1ohm in parallel. Right???
I need suggestions on an amp for 2 Alpine type r 12's. 600W rms, 1200W max, 4 ohms each, in a ported box.Looking to spend around $200.
Really appreciate any help guys,
Yes Miss Black - if he has Dual 4 ohm then he can run them at 1 or 4 ohms.
I think the OP needs to clarify what he has (dual or single 4 ohm drivers) I have never ran Alpine subs so I am not sure if they are all DVC's although a quick look on sonix looks like they are all DVC's
Either way the amp I linked is a solid unit and would last for a long time and is in his budget.
[quote=>>SQL
Just wanted to make sure. :)
[quote=>>SQL
from my know, no type r's are single coil so i assume d4
11
901
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
Kademoorman
Kademoorman
Houston, Texas
GVP
winkychevelle
    Jun 3, 2024
