Need help with amp settings
  • 4
Jeremysmith122703
CarAudio.com Newbie
So i have a 2018 chevy cruze lt stock HU with a skar 12"evl at 1 ohm in a ported sub zero box and a skar rp1200.1d amp right now i have bass eq at 0 gain is lil more then 3/4 up lpf all the way down and subsonic all the way down... it hits really hard even cracked the 3rd brake light only thing is i know its not hittin all the tones right and cant figure out wat to put those settings at... thanks for any help
Sounds like u need to turn your lpf up to at least 70 or 80 hz
Turn the log up a little
set your gain right, heres how. test tones are at the very bottom...
11
886
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
4
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Jeremysmith122703
CarAudio.com Newbie
Jeremysmith122703
Stockton,ca
nauc
