Need opinions and info on sail panel tweeters and speaker amp
  • 1
I currently have a 2005 Mazda 3 sp23 and I currently have a kicker compr 12" sub with an Alpine amp, pioneer A-series 6x8 in front and rear, a Kenwood dpx303mbt head unit, and factory sail panel tweeters. I wanted to put a kicker keysmart amp to the speakers but do I need anything for the tweeters? I will probably replace them later down the line but I am learning as I go with wiring everything together. Also what do I need to do wiring wise for the keysmart amp?
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
486
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
372
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
409
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
612
JustYourAverageImport
CarAudio.com Newbie
Sadler, Texas
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
