Needing help on a universal wire harness
  • 1
Pizzdog
So I got universal wire harness for my 2006 Pontiac grand prix. I'm tryig to wire head unit witch is a pioneer stereo. What I have done so far is connect all the wires to the right place and nothing won't turn on or nothing. So when I took a closer look I can get it on by connecting the yellow wire's to the red wires only problem it stays on and doesn't ahut off. Someone said I have to connect the red wire to ignition? I wasn't sure what they meant by that. If anyone can help me on this please it would be nice. Getting tired of plugging and un plugging my stereo when I'm in my car.
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
You got plenty of space 30"h x 40.5"w x 65"d even triple baffled, double walled with bracing. What vehicle is this going in may I ask?
6
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
5
897
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
198
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
Pizzdog
Pizzdog
Pearl harbor
Pizzdog
