new amp for subs
just get a 100a inline fuse ull be fine
more important is setting ur amp correctly
keep ur gain in check and keep bass boost on amp and headunit to a minimum
those tend to peak ur signal and cause clipping
a possible sub and amp killer
whats the differance between fuses AFS,ANL,MAXI? is one better than the other?
ANL and mini ANL are my favs.. AGU or glass fuses are ok to if you want to run lots of them for competition. MAXI fuses ****.. lol they will literally melt before they blow thats why they are banned from MECA and DB drag.. and i had one melt, shorting out costing me an alternator.
yeah like the q factor and stuff like that.. if there is a local JL audio shop they can give you a print out of the optimal settings for that amp on your subs since they are JL subs.. you may be able to find them online but i know a dealer has them.
no they arent really supposed to be avaliable to the masses.. they want you to get your stuff installed at a dealer thats why they make the "setting" sheets hard to get..
You said the subs are dual 4 ohm. Keep in mind that this means you have to wire them in series/parallel which will give you 4 ohms. Yes, the amp...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
11
https://www.the12volt.com/caraudio/subwoofer-wiring-diagrams.asp?Q=2&I=41
16
rick265
rick265
ny
dadydolas
AnthonyO
    Jun 30, 2024
AnthonyO
    Jun 30, 2024
