pc subs in car?
sorry.. i found a 250w power converter to plug it into instead.. it just has a cable that plugs into the one speaker tahts the same kind of cable that your keyboard uses
u mean like a USB? But seriously don't do that, it might even cause problems later on. Just save ur money on the tried and true route
Just buy a cheap 12" sub or so, low powered one. Then get a small amp, maybe 300watts. An 8ga wire kit and you done. You will spend maybe $125 at most, unless you find a deal here. there was a guy selling a 12" Xplode and an amp for $100 IIRC
Yeah but it's an XPlod, there's a reason why he didn't want to keep it... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
//content.invisioncic.com/y282845/emoticons/word.gif.64b12e39f936af3b4fff38a1c0bd0244.gif no need to throw money away. Get a Mach5 maw-12 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I hooked a 4" vented computer sub up to the stock amp in place of my 6x9's once.. the factory amp had enough to blow that useless thing in like a night. Heh. It worked for a little while though.
Nothing wrong with the system. humming sound. Just the amplifier. Just switch it to volume maximum, then enjoy the music there. Loud. Sorry...
12
Most likely your ground. I've seen that happen, the sub looks like it's playing a 5 Hz note. If one piece of equipment doesn't have a good ground...
Sounds like you shorted the other channel so check you connections. Don't ask just look. Will solve your problem Every time. If you ever short out...
9
When your battery runs low while playing music, the radio will make odd sounds. Charge the battery and when installed, play the music with the...
65
mrwaffle
mrwaffle
baltimore, md
ShiningBuick
BassErex
    Jul 3, 2024
BassErex
    Jul 3, 2024
