Please help me understand crossover wiring (giving up on searching)
  • 4
lmx107
DC
Hi everyone - I am a new member on the forum and need a little help understanding something (and believe me I've searched and searched on this issue using google, forums, vendor sites, car sites, Youtube, images, amplifier and component speakers manuials, etc. and have found nothing to help clarify).
On a 4 channel amp. If I attach the output wires from channels 1 & 2 (tweeters) to the crossovers' inputs (assuming this is the correct way to wire it), then from the crossovers I connect separate sets of wires to go to tweets and mids. OK easy enough.
What I don't understand is how much power are going to the speakers? If the amp is rated at 50W RMS/channel, does that mean the 4 speakers are getting only 25W each (since all 4 speakers are being fed from only 2 channels on the amp)? What does one do with the remaining channels 3 & 4 on the amp?
I would love to see some definitive source say something like:
On a 4 channel amp:
Connect your tweeter output wires from the amp to the "input" on the crossover.
You won't use the remaining 2 channels (3 & 4) on the amp
or you can bridge them and run a sub
You will get xxx watts on each speaker
etc...
Thanks so much in advance for anyone who can shed light on this. I've been pulling my hair out and done with searching.
X amount of watts PER channel means exactly as it sounds. 50w x 4 channels means each channel puts out 50w at the specified ohm load that it's rated for. A 4ch amp can be used as a 4, 3 or 2 channel amp.
Back to what boomin said, what amp and vehicle and speakers?
Thank you very much for your replies.
My amp is a Soundstream PN5.640D. It is a 5 channel amp rated at 60W x 4CH + 200W at 4ohms.
My car is a 2 door, 2008 VW GTI with a factory radio called the Premium 7 (no factory amp) and has 10 speakers. Each side of the car has 5: Front (tweeter, midrange, and woofer); Rear (tweeter and woofer).
I am trying to upgrade to a set of Hertz MPK component speakers that has only tweeters and woofers and also adding a 10" pioneer single sub as well.
I am downsizing from the 10 speakers to just 5 (tweeters, woofers, and sub) thus the use of the 5 channel amp. I don't know how to wire all 10 speakers so will just go with what I know. The factory wiring is a mess because the color coded wires are different at the HU and at the speaker harnesses.
-The design is to run high level outs from the HU to a LOC (AudioStream LC7i, which combines signals and provides a separate sub channel)
-Run 3 sets of RCAs from the LC7i to the Soundstream amp (Fronts, Rears, Sub)
-Run channel 1 to xover in driver door, then run wires to tweeters and woofers
-Same for channel 2 for passenger door
-Run sub off of channel 5 (200 watts at 4ohms)
-Leave channels 3 and 4 alone
@THATpurpleKUSH - I see what you mean but I am still confused. If I have 60W per channel, and I am wiring 2 speakers to that one channel (through the xover), doesn't that mean it's 60W / 2 which equals 30W per speaker?
Just about 2 hrs ago, someone also explained to me that the speakers actually receive 60W EACH. The xover just splits the frequencies and thus, doesn't impact the amount of power each speaker gets. If this is true, then I am not sure why I'd even need a 4 channel amp (not considering the sub's 5th channel) if I could power the speakers with just 2. What am I missing and is there a better way to get the full output of the amp to all the speakers?
Thanks in advance for your help.
[quote name='lmx107']Thank you very much for your replies.
Thanks in advance for your help.[/QUOTE]
A crossover is a filter that allows a speaker to play a certain frequency range. Both the mid and the tweet will see the power rating for that channel but the mid will be playing from whatever you set the low pass filter on your headunit to the crossover frequency which is usually anywhere from 2.5khz - 5khz. The tweeter plays from the crossover frequency to it's upper ability usually around 20khz.
Yes essentially the mid and tweeter will share the wattage.
In some cases the cross over net work will split the power in other ways such as a 60:40 ratio using resistors and other components on the crossover board.
In other cases and I believe the mpk crossover is one of them you can biamp the cross over dedicating 1 channel per speaker while still using the cross over to control the crossover points and protect the tweeter. This is nice if you have time alignment but not active crossover network capability.
Assuming you don't have the ability to time align of actively set your cross overs my opinion is you should bridge the amp front and rear one to left one to right crossover then let the crossover control the frequency setpoints. If you have time alignment but still no active crossover network biamp the crossover.
If you have time alignment and active networks and are comfortable in taking the risk at setting your own crossover points ditch the crossover and run straight off the amp.
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
lmx107
lmx107
DC
lmx107
winkychevelle
    Jun 3, 2024
