Possibly starting my own line of woofers...
audio_phill
Walking TSP Encyclopedia
Pondering dropping my own line of subs instead of just having me some built for my personal system, Got proto tsp's pulled, fits in its own niche, will not be flashy but is fairly clean aesthetically, and except for cone and spiders from proven platforms we are all familiar with everything else is new tooling. Heres the tsp's. My idea was to target the true sql market with a sub that is capable of respectable output and transience not seen in the price range. Basically, I wanted 30Hz to blur my mirrors, 45 to hit me in the chest like an explosion and to hear when the bass guitarist slides his fingers up the strings and for the sub stage to blend seamlessly into the front like is associated with a/d/s, focal, etc.
Proposed Photos of Final (this is exactly what they will look like)
Re 3.96(series)
Fs 29
Qts .26
Qes .3
le 3.7mH
Vas 39L
Sens 87.07dB
Xmax 22mm
mms 288grm
BL 25.7tm
800rms
If enough interest builds I will become a vendor and take this further, price
is still in the works but should be around the $180 mark
I'd probably grab one if they look decent enough. I'm almost always up to try something new. I always thought that took a lot of upfront capitol to start your own line....
To do it in the USA it is, But I don't think it is nearly as expensive when you look out of country.
Sort of true, however there is so much more then that to it.
Where you have it built, what parts, and quantity you plan to build in all changes the pricing.
I want my own line. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
me too... //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
That's subjective. Personally, I find the hot/shrill sound produced by the comb filtering to be unbearable, so I wouldn't even listen to the...
20
3K
ok so i realized the one u gave in the example did the same video stuff so i see the one mentions 13 band equalizer but the other has "higher"...
17
Guess so Spokey! Guess we have all been ripped off then! Whatever this guy is smoking he needs to really lay off. Either that or quit going out...
18
This could be due to a voltage drop. There's no constant voltage going into the head units. It's always changing. At which point this could be...
8
audio_phill
audio_phill
Small Town VA
Falcons
HandsomeSteve
    Jun 5, 2024
HandsomeSteve
    Jun 5, 2024
