Sealed Enclosure for Hertz 10" subwoofer
  • 2
DeruDog
24
UK
Vehicle: 2012 VW Passat CC
Location in the vehicle: back deck
Space available (Length x Width x Height): 44x24x5
Subwoofer make and model: Hertz HX250D or JL Audio 10TW3D4
Subwoofer Size: 10"
Number of Subwoofers: 1
Type of Port (Kerfed, Slot, Aero, etc.): Sealed
What type of music do you like?: Acoustic, rock, blues
Is your goal SPL or Everyday Music?: Everyday Music
Volume: 100dB or below.
Questions: I would like to decide between a shallow sub that will fit easily in a thin box on the back deck, and a normal sub where I would have to build it up.
In order to fit the Herttz HX250D, I would have to add a 3 inch riser on one side of the enclosure on my back deck. This would impede visibility a bit, but visibility is minimal out the back of this car anyhow. If I did this, it would have about 3/4 inch clearance on the bottom, and about the same on the right and left sides. Front and back would have several inches. Would this lack of air flow be a problem?
I would have the proscribed amount of air in the enclosure, but it would be in an enclosure about 3" tall in ID. Would this flat-type box cause any issues?
Thanks.
Any reason why you wouldn't install in the truck instead? Seems like an awful lot of work to save 1 cubic foot of trunk space.
I will soundproof the cabin separate from the trunk. Don't want to put the extra money into soundproofing. It's a big trunk.
And you (if you’re not a Ai BOT), for the sake of everyone in this forum, may want to quit posting, Your information is consistently off topic and...
48
7K
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
I dont think this forum is letting that link work. It keeps changing it to a link to this forum. Try this. Just change the dot...
10
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
12
DeruDog
DeruDog
UK
DeruDog
winkychevelle
    Jun 3, 2024
