Setting Gains with LC2i! Still unresolved :(
LOLOL IDK HOW THIS HAPPENED. APPARENTLY AT SOME POINT MY BASS EQ WAS SET ALL THE WAY DOWN. IT MUSTVE BEEN THIS FOR GOODNESS KNOWS HOW LONG. THIS EXPLAINS EVERYTHING. I FEEL SO SILLY. DIDNT EVEN THINK TO CHECK BECAUSE I NEVER ADJUST IT
That shouldn't really make a difference. If you set the voltage with the bass all the way down, but are reading 44.7, it's still the same power you wanted it to be. If you raise the bass eq, you're voltage is going to go up.
Oh shoot! I got excited because I thought I figured it out. Haven’t tested it yet. I discovered this like 10pm last night when I got home
At least you're making progress
Well actually very interesting…. Was working on it and the bass eq was ALL the way down??? Is there a feature where the Lexus HU would automatically drop it? I’ve no clue how it returned to that position? Unless I really just brain farted and didn’t realize I might’ve accidentally put it down. But right now, it’s good! Spoke with JL and audio control, and had like a 30 minute conversation. Disposition: f*** voltage. Set each to just below maximized/clipping light activates.
Just reset it. I set bass eq-1, actually. More so to drop bass from dash/doors/etc. sounds lovely. Had a hideous rattle so made a makeshift amp rack which resolved that. Next step is removing rear seats and dynamatting the rear panel. And then further matting trunk. Thank you All! Think I’m nearing the completion.
Personally, I set the eq the way I like the sound, then adjust gains after to make sure I'm not going to clip.
Basically, get the gains close, set eq to your preference, then finalize gain. I know on my last system 28 on the hu was fine. Above that was a chance of clipping, which I was ok with for 1 song but not more than that.
Glad to hear it's resolved.
Unless accubass has changed it will increase voltage and really serves "no purpose" in car audio since cabin gain already "restores" bass roll...
15
861
That's nothing but an annoyingly common phrase to try to sound smart. Don't say "gain is not a volume knob" until you can explain how it differs...
10
Sounds like you got it set correctly.
zoltman1991
CarAudio.com Recruit
zoltman1991
houston
Jimi77
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
