The impregation process causes them to solify acting like a peace of resin instead of just strengthing the cloth..Didnt we just have a discussion on break in periods last week and agree that they are not necessary? Ive yet to hear an explanation as to why stiffer spiders require a break in period to avoid damage.
and still can't take down DD lolzA-Team has ran that thing on a stetsom 11k in free-air for over 3min before...
a ton of drivers DO require a break in period. Granted a lot are home theater drivers but need it just the same. DD's and AQ's need to be broken in because the spiders are laminated and designed stupidly, it isn't do to being stiff. It's because if you don't break them in they won't soften up evenly and end up with hard and soft spots that will cause them to rip and tear. A true break in period is going to take longer than 2 weeks unless you play them non stop, 120 hours is what is recommended for the most partDidnt we just have a discussion on break in periods last week and agree that they are not necessary? Ive yet to hear an explanation as to why stiffer spiders require a break in period to avoid damage.
So why will a long period of low vibration make a difference versus a short period of 'normal' vibration?The impregation process causes them to solify acting like a peace of resin instead of just strengthing the cloth..
Any testing or other data to confirm this? This goes along with my query to papermaker.a ton of drivers DO require a break in period. Granted a lot are home theater drivers but need it just the same. DD's and AQ's need to be broken in because the spiders are laminated and designed stupidly, it isn't do to being stiff. It's because if you don't break them in they won't soften up evenly and end up with hard and soft spots that will cause them to rip and tear. A true break in period is going to take longer than 2 weeks unless you play them non stop, 120 hours is what is recommended for the most part
to the dd/aq spiders or the fact certain drivers need to be broken in to perform at 100%? I think mark audio has a pretty detailed paper out on why it's required for their fullrange drivers. It has a lot to do with making sure the spiders break in the same all the way around and stay the same stiffness from inside to outside.So why will a long period of low vibration make a difference versus a short period of 'normal' vibration?
You are merely saying that you should over drive every decent product on the market because it is sold that way? All though many follow your thought process, I am telling you that you are indeed wrong. Yes there are marketing tricks but most of this is for warranty standards and not to increase sales.Rated RMS by the manufacturer is the same as the RMS they give to amps. they get to pick and chose what they throw at it. look at SA 12s, 600rms and are doing 1k daily without any problems with designs. Why do all their amps do more than rated at the 14.4 or 12.9 Voltage? its a marketing technique.of course you shouldnt be running 3k. adding in the aluminum coils will give it that extra shove to RMS daily runnings.
The reason i stated my Numbers and what others were running was to show what i was against, and their setups as a unit of comparison i might add.
The issue that was with the spiders in several layers were that many of the inner layers would not receive much if any glue do to the assembly method. Being easier on it was their way of combating the issue of less then required glue on the joints. With that said, they have changed their build method and they have also changed the number of spiders on the drivers(all though that was for other reasons). The noise you would hear is the inner layers of the spiders moving around do to lack of glue.DJ explained to me that the layered spiders "could" separate if given too much power too soon as only 1/2 of them would take the brunt of the power. This was the noise some subs had as the spider layers were tapping against each other. Over time they would take a proper set, but it's best to just give them a chance from the start.
I've never witnessed it personally, but I've always been religious about doing a break in on fresh recones.
Indeed we did. After I reworked my findings I found other similarities that made me recant my original findings and send out an email to a few manufactures regarding those very issues.Didnt we just have a discussion on break in periods last week and agree that they are not necessary? Ive yet to hear an explanation as to why stiffer spiders require a break in period to avoid damage.
