Sony XS-GS 120LD opinions and suggestions.
NMNXX
So I picked up a pair of Sony XS-GS 120LD Subs. I am not sure if I made the right choice? I went to a local car audio retailer and got sold on them, now I am not so sure. The guy took me out to his chevy Tahoe equipped with 4 of the same subs and supposedly a Planet Audio amp was powering the four. I was kind of in a rush and told him I would get back with him but he stopped me and said those same subs are on clearance today. Well Long story short I bought them only to find out I could of got them cheaper online but only by a couple of bucks so I cant fault him for that. I did read a good review on PAS-MAG Online but could really use your opinion on the subs and possible wiring and decent priced amp for power suggestions. Sony XS-GS 120 LD Dual Voice Coil 4ohm 400RMS, CEA 2031 520RMS, short term Max Power 1500, 30-1000 Hz. Thanks!!!
2 d4 subs can be wired to 1 ohm. Wire each sub in parallel and then parallel to the amp will be a 1 ohm load. There are many pictures available of wiring diagrams for a 1 ohm load
782
I just got a sony cdx-f7715x put in my truck. It’s in demo mode right now cause I don’t have a remote to access the menu. Is there any way I can...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
That looks like it can work for backup cam for sure, thanks
946
Did the articles on issues with this unit not getting audio directly after installing, have any fixes. Is it possible that you are experiencing...
NMNXX
NMNXX
roodhouse illinois
NMNXX
Doxquzme
    May 22, 2024
1aespinoza
    May 22, 2024
