*Sub and Amp in a Truck... how*
  • 2
There are plenty of option if worried about space use a single 12 a good quality single sub will do the trick if you need even smaller get a shallow mount sub infinity offers a nice one and they don't need large boxes a single sub will be more then enough if its set up right, you know the old saying I you had to have 2 subs you didn't spend enough on th first one applies in this situation.
272
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
795
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
858
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
9
900
mbonin21
mbonin21
Rochester, NY
Hookedup12
