sub help
  • 3
utrook31
I recently bought and installed an amped bazooka tube. The only problem I'm having is that right now its set up so that it turns on whenever there's a signal, so between songs there's a loud click.. which i'm guessing is the sub turning back on after having turned off. Doesn't happen when i'm listening to the radio. This is the first time i've ever installed a sub so not sure how to fix this problem. Anybody know how to fix the problem?
in case he doesnt know what that is, its a cable running off of your amp to a metal piece of equipment on your car, usually about 2 feet away from the amp. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
well.. I had to find a decent ground just to get the bazooka to work. If it matters any.. my ground wire is like 3 - 4 feet long. And it only happens when the HU starts up and between tracks on cd. Any other ideas?
nm... think i have a solution. There remote turn on wire should be connected to the antenna wire from my HU right? I was lookin in the installation manual and they kept talking about their on/off switch.. so that confused me. But I should be ok with just connecting the remote turn on wire with the antenna wire from HU right? BTW, thanks for the quick responses.
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
722
Resonix is supposed to be the bees knees, but it is a little $$. If I was doing the whole car, probably would shell out for the entire resonix...
25
3K
2400w x 4 peak and 120w rms x 4. That has to be world record dynamic right there 🤣.
28
utrook31
utrook31
Garland, TX
80_Cutlass_mn
Hobib Ali
    Jun 24, 2024
1aespinoza
    Jun 23, 2024
