Question?
I have a 2 ch amp the is rated at 130W x 2ch at 4 ohms or 200W x 2ch at 2 ohms or 400W x 1ch at 4 ohms (bridged).
I would like to run two sub off this amp. would it be better to bridge the amp to get the 400W x 1ch and wire two 8 ohm subs in parallel to so the amp with see the 4 ohm load, or should I wire two 4 ohm subs to each channel separatley.
I am going for the best sq possible
