Subs/Amp cutting out with high volume
  • 5
Does it have pins inside and is rectangle? Most amps have this for those that wanna run stock HU and no RCA's.
Id have to go look at it to be sure but I don't think so. I'm really thinking the problem is just ****** HLC and stock HU. I've never experienced this problem on an aftermarket and I'm typically on top of voltage drops not being an issue
You said the subs are dual 4 ohm. Keep in mind that this means you have to wire them in series/parallel which will give you 4 ohms. Yes, the amp...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
11
https://www.the12volt.com/caraudio/subwoofer-wiring-diagrams.asp?Q=2&I=41
16
Palmer92
Palmer92
New Jersey
BOOMINGRANDPA
AnthonyO
    Jun 30, 2024
AnthonyO
    Jun 30, 2024
