audioholic
not a moderator
I find it to be an interesting concept as well. Not saying its pratical, hell I have no idea, nor really care. Its still interesting.
High tech bathroom fan. If it does what it says it does then it would be pretty sweet, but for some reason I am doubting its abilities.How interesting. I always keep my mind open to new ideas, but it does bear an uncanny similarity to my bathroom fan. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It is only reasonable to doubt its abilities. By today's audio standards it is very near impossible to reproduce what this fan claims to be able to. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gifHigh tech bathroom fan. If it does what it says it does then it would be pretty sweet, but for some reason I am doubting its abilities.
[/QUOTE]"The coolest product at the show was this Eminent Technology unit that produces 110 dB at 10 Hz. It is designed to supplement subwoofers (!!!) in the 5 Hz to 20 Hz range. A 1/3 horse power motor turns the fan blades, which are connected to a rod in the center of a woofer voice coil. Instead of the voice coil moving a cone, it moves the rod, which then moves smaller rods that adjust the pitch of the fan blades. So, the high velocity air coming from the fan is pulsed at the low frequencies. It only takes about 100 watts of amplifier power to drive it. The entire room shook, and the door was opening and closing in time with the signal. All this, and there was almost no distortion (the ET rep had the response being plotted on a spectrum analyzer during the demonstration). They calculated that it would take ten 18" subwoofers to produce this level of sound. It has to be placed in a separate room due to the fan noise, and putting it in the attic would work fine. The opening into your home theater would be about 2'x4' in the ceiling. These are prototypes at this point. All I know is I want one."
Yeah, I think the concept sounds like it would work in my mind. I want to demo one.honestly, it looks like a solid idea, and the concept seems to work out in my mind. they are pushing air like a convetntional fan, as they are oscilating the fanblades at the frequency derrived by the amplifier. considering its >40hz only, its JUST subbass as the blades cant go more than 40 cycles per second. it seems to be quite a good idea to me.
and to all you haters out there, have you heard it?
no. so shut the f*ck up. post your well thought over oppinion, not your baseless truths.
