Taramps MD or Bass
Whats the difference between these amps? The MD is rated for the same power at lower voltage compared to the bass line. And the MD is cheaper.
What makes the bass line more expensive? Is it better for lower impedances, running below rated impedance? I see a lot of recommendations for taramps around here, anyone know? Is one more efficient than the other.
Better is always dependent on application. Like I said unless you are wiring under 1 ohm I would run an MD. There is an MD12k .5 ohm version though.
The DSP line will always be my favorite from Taramps but unfortunately they did away with the 3000, 2500, and only producing the 1600 now.
Now, I feel like I cheaped out by getting the MD line when the Bass line was the better choice.
Oh boy do I know too much about that... 20 years as Type 1. :poop:
13
Damn can I hire sancho for her so she can buy me a new set of 12" Fi subwoofers?? :D
6
I'm hoping 🤣 I still gotta decide on drivers up front but I might just the cdt components I got now and add a unity mid 🤔
42
7K
I ran the Orion for about a year, then I bought the Taramps when I though the Orion broke. I found a knick in the Orion bass knob that was causing...
T Reds 19
T Reds 19
Akron, OH
Psi_optima12
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
