SOLD TC Sounds TC2+ DVC 12" subwoofer
mvw2
Specs:
T/S parameters
Re: 4 ohms (per coil)
Qts: 0.374
Qes: 0.422
Qms: 3.265
Fs: 22.7 Hz
Res: 7.5 ohms
Le @ 1kHz: 4.7 mH
Eff. Diameter: .252 m
Vas: 130 ltr
Mms: 132.2 g
Cms: .372 mm/N
BL: 18.29 N/A
SPL: 87.4 @ 1W-1m
Watts RMS: 400 watts
Xmax: 19.3 mm
Manufacturer's site:
http://web.archive.org/web/20050404094314/www.tcsounds.com/TC2plus_12_2578.htm
http://www.oaudio.com/TC2_PLUS.html
I've had this sub for a little over a year. In recent, I've tried a couple other subs and have fallen in love with Dayton's Reference series. Sadly, I'm letting this one go.
$100 OBO
Trust me, its a TC2.
I think I would know, ive had over 150 TC woofers in my stock //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Then I guess Oaudio's been selling the wrong woofers for two years. Looking at the specs from TC Sounds for both the TC2 and TC2+, it does show that the TC2 and TC2+ use different sized motors as you say. However, I still believe this is the TC2+. The magnet width is a full 6" and is flush with the basket. The TC2 shows only a 5.25" wide motor and a noticable ledge between the basket and motor. The TC2+ is flush instead.
TC2:
http://web.archive.org/web/20040316085939/www.tcsounds.com/Images/12tc2_2576.pdf
TC2+:
http://web.archive.org/web/20040728232055/www.tcsounds.com/Images/12tc2plus_2578.pdf
From measurements and even just the picks, it seems pretty obvious that mine is the TC2+. I don't know what to say. It would just seem odd that they would sell the TC2 under the TC2+ name and not have someone to complain for 2 years.
my 10" from Oaudio didnt come with an aluminum cone and it came with a grey basket. do you still have the oaudio sticker on yours? it should say the driver on it.
No stickers, flat black. The box just says Oaudio. The cone has the plain aluminum back but flat black painted front, no decals. There's a small sticker on the side of the motor:
Oaudio
Serial number
Build date
Neither the box nor the sub indicate exactly what the sub is, only the website.
Maybe the picture doesn't do the motor justice. It would just seem blatantly obvious if the motor was only 5.25" wide. I pulled the tape measure out, and the motor is the 6.125" that TC Sounds says is the TC2+. I could give you a tape measure shot if you want. Maybe the motor looks a little small when you're looking at 7.5" TC9s all day.
bigj06040, can't see that ever happen...unless it was a busted sub, i.e. paper weight. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
supa_c, agreed, we'll believe our own beliefs. I'm just siding with Oaudio and the manufacter on this one. It was sold as a TC2+ and the motor's dimentions mimic a TC2+'s motor as described per the manufacturer. How it could be a TC2 //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif no clue...
The TC2+, I'm keeping. I thought it was a steal for $100, but I guess nobody wanted it. Now it's mine, all mine!!! haha! :p It should find it's new home in a nice ported box in the somewhat near future.
I was able to log in fine, using Chrome if that helps. I don't know anything about the product at all, just found the info and shared the love. :)
4
731
Brother in law has some of their 8’s and they are little beasts. Typical cookie cutter product that performs as it should.
Off the shelf design, nothing special and will sound like a bull horn. The best pro audio drivers I’ve heard are the crossfire XTpro6’s. The best...
6
mvw2
mvw2
Rochester, MN
mvw2
BassErex
    Jul 3, 2024
BassErex
    Jul 3, 2024
