The XXX subwoofer SPL myth...
I didnt see the run myself but it must be a horrible setup it should have at least did a 145, but im not sure what type of nox he was using
That wouldnt be a huge problem... I think you are imagining the high out put capabilities of the XXX. Never know, the XXX may have liked your box better than the other subs you had in there.
Question I have is Have you bought anything yet? Amp;? If not.. What vehicle and what is your budget for subs and amplifier,wiring kit and...
5
142
Since the meter is set to a higher resistance, it is not going to give a "fine tuned" reading. At 200k Ohms, 100 Ohms +/- is not an issue. When...
8
200
I knew this day would come. AI will replace everything we can do. It may or may not work right now, but eventually this one or someone’s will...
6
541
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
toaster
Installer, since 1984
toaster
Nettleton, MS 38858
Brian Owens
Hobib Ali
    Jun 24, 2024
1aespinoza
    Jun 23, 2024
