Tweeters are irritating
red1ty1
hello, i hope someone can help me. I have the Polk SR6500 series speakers and im havomg some problems with them.
the first is that the tweeters seem to have an irritating "S" sound to them when their are any vocals and it is bothering me so much.
also I keep hearing distortion come out of the passenger side tweeter but it is very faint. It is more of a crackle from tje tweets. i have the speaker cable passed on the same side as my power cable for now and im hoping that will solve my distortion issue.
i would like to add that my old infinity tweeters distorted/crackled also.
any help?? thanks to anyone who can help
my setup is.
Clarion cz702
Polk Audio sr6500 speakers
RF p450.4 4 channel
RF p600.1bd monoblock
skar audio vvx12v2
i have already tried other amps for my speakers and its the same.
when turning up the volume on my headunit i hear ticks or clicks every step i go up or down. i think i should get my headunit warrantied maybe...
the tweeters are not aluminum im not actually sure what they are.
my gains are actually too low. anyways this weekend im going to put my speaker wire on opposite side of the power and see if that fixes it. along with some eq tuning and phase configurations. ill see if that works
U r right they are fabric do u have them aiming towards ur windshield? Also u can try to cut the 12kHz freq too. Also what is ur source... phone cd usb...
I habe the samething with some crackle on the passenger side mine started when I started to use time align
you mentioned your wiring. try a simple test to rule out wiring causing the issue. If you can remove the tweeter. wire it directly to the amp with a short piece of speaker wire. See if the crackling noise is still there . If it's gone your wiring is the culprit. you probably have a short somewhere.
I did an adire koda 8 for now but I'm considering swapping it to a Dayton ho 10. More cone area for more midbass. But I might not need to. I might...
16
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
9K
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
red1ty1
red1ty1
Montreal, Canada
ramos
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
