two 2ch amps
Joemon
Product I'm looking for: 2ch amps for mids and highs @ ~300watts a channel at 2ohm or two 4ch amps used bridged
Budget: Depending on amp I can do $100-$200.
I'll have a Kenwood excelon x600f amp to trade for also
Condition: working please Would like to be fairly clean condition
Time Frame (if applicable): anytime I find something decent
pm'd
pm'd you
Diamond Audio D5 300.2 rated 75x2 but does more. I have run it and its def more than 75. the 4 channel 600.4 was reviewed and it did significantly more than rated. made in USA.
bridged its closer to 500 than the rated 300
$90 shipped.
I've got a BA gt 28.
250 watts x 2 chan. @ 4 ohms
450 watts x 2 chan. @ 2 ohms
900 watts x 1 chan. @ 4 ohms
1250 watts x 1 chan. @ 2 ohms
$200 shipped.
Looking for something I can get the same matching pair. I know I may not find someone with a pair for sell but in a week or so ill be buying someone's amp
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
466
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
583
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
You don't need two amps. The speakers come with crossovers to help protect the tweeters.
14
Perhaps you changed something without mentioning it here? Maybe a loose turn on line? I dunno man...but we'll take it. Hopefully it keeps working. 👍
16
Joemon
Joemon
Modesto, ca.
Joemon
