Using 2 batteries: 65 + 24 size
OKAY
it'snotdatloud
I was given a battery (24F-VL Valucraft) that has been sitting for about a year. Tested 12.59v. Until I'm able to afford an AGM for under the hood, would leaving the main battery in and placing the 24F battery in the back worth it? After the cost of wire and all.
3000 rms brutis brx3016.1d is struggling on my battery.
Thanks, again!=)
Thanks, again!=)
I wouodnt but you are aware that I can sell you great batts dirt cheap right? Agm and all that. And wire wise all youll need is a new piece that goes from the + on the battery to your amps power and a piece that goes from the - to the ground on the amp. $115 shipped and youll have all the reserve power you need. Let me know
Just scored this on Marketplace and he threw in the DSP. Excited about going active with the amp. The DSP wasn’t the one I was ultimately looking...
9
576
Generally you are not supposed to use high level inputs and low at the same time on a car amp. Reason is simple. The power of the amp runs through...
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I hold firm on the deposit in all situations 😎
9
OKAY
it'snotdatloud
OKAY
I.E. 951/909
michaellane
AnthonyO
    Sep 7, 2024
AnthonyO
    Sep 7, 2024
