Warhorse eletrical recommendations
It is not good for competitions. It works wonders for daily and 'wow' factor. It's too strenuous on electrical for proper burping and the push/pull make it incompatible with SVC woofers or an odd number of woofers. It also is a higher ohm load than most other 10ks and won't go near the high spectrum of input voltage. Those are probably some of the reasons. As far as 10k amps go, she's dirt cheap.
you're right...for competing it's not that great. For daily it would be better. We had the proper electrical for them, just didn't put up #'s like we thought it would
It definately has it's place though and they can be had for good prices
My god, why XXX's, they're totally not a SPL sub, being that they have only like two spiders on them.
And x10 on suspension. I have a Jeep Cherokee and just to feed my 18's and 5kw amp, I've got 6 AGM batteries which with the wall added 1600 lbs of extra weight. The stock springs buckled, which is why I have air ride on it now.
If you haven't been doing 3kw+ builds before, you really should get someone whom has to help you.
Dont care for numbers, daily driver than just loves his music //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I like the feeling of almost being in a death metal concert everywhere I drive //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Everyone just has a boner for Sundown amps and tries to move everyone off of Kicker eq. Honestly, though, if you aren't going to put serious money into electrical, a 4500 would be better. It would also be a better match for those REs. If you are just going to run two of them, you wouldn't be using half that Warhorse anyways.
No boner for Sundown, it's just common sense like you stated. He doesn't have the money for electrical, or the space for it, or the desire for it, or the need for it. He wanted an SAZ-4500, he could easily afford that and the necessary upgrades selling this thing.
Never said they were. Commentary was more to being able to purchase one or the other or 40% off and take a 90 day warranty... which I would in a...
796
Doors and dash? Year, make and model of the car? Amplification? Midranges or coaxials? Need some more specifics about what if anything is already...
528
Heck...done right...you could get an amazing sounding stereo using $15-25 drivers from partsexpress 😂
916
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
I read your post and thought about all the aftermarket decks that were installed using the factory power wire. This is why manufacturers quit...
92
6K
CARP3T
CARP3T
Dallas, Texas
brodeisel
